Trent Couch
While installing camshaft bushing in the block of my Farmall m
I installed the middle bushing and the front bushing and got all
of the holes lined up on the bushing with the holes in the block
however with the smallest bushing or ?rear? bushing it only
has one hole on the bushing but the hole in the block itself
has two holes one coming from the race where the main
bearing sits and the other hole goes directly into the block
which hole should this bushing line up with. I thought maybe
you had to drill out one of the holes once installed but my old
bushing only has one hole to but it?s been so long I can?t
remember where it was lined up.
Thanks
Thanks
