Johnnykick
Working on a 1955 International 100 industrial model by Farmall. Discovered I have a large crack in the right rear rim?explains all the rust I found as you can see clear through it. I?m now in search for a salvage rim. A neighbor dropped by and noticed that the left rim is wider than the right rim?9? vs 8?. Indeed, when I look at the parts catalog I see 2 part #s?51281DB width is W8, and 56205DB W9. The W8 (right side) has the 150 pound weight whereas the left does not have a weight. Both have the same size tires?11.2/10 X 24.
What?s that all about?
Rim and Foot Pedal Rod
