TractorLinks.com
Show Parts for Model:
Farmall C
uvilla
07-11-2018 05:45:08
Does anyone have a puller i can borrow to remove front pulley on a Farmall c
gene bender
07-11-2018 06:25:19
 Re: Farmall C in reply to uvilla, 07-11-2018 05:45:08
You do have the steering sector off because the pulley will not come off without the sector removed. and you do need a steel plate behind the pulley or you will break the pulley.
uvilla
07-11-2018 06:22:39
Thanks So much.....
ih560
07-11-2018 06:18:40
Be careful if you use a 3 jaw puller to remove that pulley, many of those have been chipped or cracked by doing that.
Best way is to cut a steel plate to slide behind the pulley with two tapped hole for bolts or threaded rod to a wheel puller or better yet a bar puller like this:
James Williams
07-11-2018 06:16:11
I will try to pick it up Saturday mourning and bring it to you,Ive saved your phone #
uvilla
07-11-2018 05:54:46
Sorry Shenandoah Junction Wva 25442
fbh44
07-11-2018 05:54:35
I borrow tools from my local friendly O'Reilly's Auto. Free.
ih560
07-11-2018 05:50:50
Where are you located? There may be someone close to you that can help you out.
