TractorLinks.com
Show Parts for Model:
H hydraulics lift wheel rake?
Rogstown
07-10-2018 18:08:54
Should the farmall h hydraulics be able to lift this h & S v12 wheel rake? I believe the total rake weight is 1400 pounds. I don't have a hyd. Pressure tester to check. Also I put 303 fluid in it because other newer tractors use it as well
tjv
07-11-2018 20:50:38
 Re: H hydraulics lift wheel rake? in reply to Rogstown, 07-10-2018 18:08:54
We have an H&S bi-fold 12 wheel rake and used to do it but the H struggled and if it's the one with the hydraulic fold option the H couldn't do it our had the belly pump live hydraulics may be a slightly higher pressure and sneak by
rustyfarmall
07-11-2018 10:17:53
I used my dads Farmall H to plant corn. John Deere 495A, 4 row, with a full compliment of herbicide, insecticide, and fertilizer boxes. Fully loaded, the belly pump lifted that planter just fine.
DR. EVIL
07-11-2018 05:39:25
Early belly pumps were rated 500 psi, later in productiion tolerances were improved and were rated 850 psi. Rebuilds after that time also improved early pumps to 850 psi.
If you have the same fluid, #303 in the cylinder on the rake and the H, park the tractor close to the rake and hook the hoses up and try it! Remember, cold fluid is "thicker", more viscous, hot fluid is thinner, tractor won't lift as much with hot fluid as it will with cool fluid.
A larger diameter cylinder will make up for the low psi. Going from a 3x8 cylinder to a 4x8 cylinder increases lift capacity by over 77%.
David G
07-11-2018 10:06:24
 Re: H hydraulics lift wheel rake? in reply to DR. EVIL, 07-11-2018 05:39:25
Larger cylinders also slow the lift down proportionally to the lift increase.
DR. EVIL
07-11-2018 15:17:35
 Re: H hydraulics lift wheel rake? in reply to David G, 07-11-2018 10:06:24
For a hay rake you lower once when you enter the field and raise once when you leave the field, that shouldn't be a problem. Larger cylinder always gives you a finer control of lifting/lowering an implement. Dad always used a 4x8 stroke control cylinder on his plows & disks with the LiftAll, want to raise the plow 1/8th inch, you could with a 4 inch cylinder, probably not with a 3 inch.
David G
07-11-2018 18:18:06
 Re: H hydraulics lift wheel rake? in reply to DR. EVIL, 07-11-2018 15:17:35
That is true, I am just not a patient person, do not like to wait
Janicholson
07-10-2018 21:17:02
Or PTO Driven pump. Jim
David G
07-10-2018 19:13:13
I would doubt it, the wheel rake worked my H pretty hard with the live pump, doubt it would work with belly.
DeltaRed
07-10-2018 18:41:48
Don't think a 'belly pump' will have enough poop for your rake. A 'mag' pump should handle it with no problem.
