F 300 RC - What to do?
I own two Farmall 300 row crops - one runs, one is for parts. The running one has IPTO but NO TA. The parts tractor has TA, but no IPTO. I believe I've gotta replace the clutch in the one I use cuz it is very jerky--a broken spring in the pressure plate???
How do I get it all-TA and IPTO? Or, is it easier to swap out the one with the TA and change over the IPTO or vice versa? thanks/ kelly
do you really need the t/a ? if so add one , I don't want one on a tractor of that era. sorry just my nickel.
I think the easiest way to go may be to transplant the TA section from the parts 300 into the runner, but I think you can also pull the TA unit from the parts 300 and install it into the TA section of the runner. Either way you would be combining parts from both.
The IPTO is powered by a shaft that runs inside along the bottom of the transmission, TA housing, and rear end. To use the parts 300's housing you'd need to install a couple of bearings, I think. The path for the IPTO shaft is already there.
