I have a 46 Farmall A and have a question on wiring.
Current set up:
1- has a 6 volt positive ground
2- has a 4-position switch (although the label is O-D-B)
3- there is a wire from the switch field resistor terminal to the F terminal on the generator
Reviewing various wiring diagrams, this looks good and the tractor is charging and operating normally.
However, there is also a wire connecting the F terminal on the generator to the F terminal on the cut out relay. I have not seen this connection on any of the diagrams that I could find.
What does connecting F to F do and should I leave it or remove it?
Thanks for any help!
Current set up:
