IHC W-30....Zenith 5...
banjoman09
Yes- my tractor runs great! However, has anyone ever heard of the "bottom bowl" of these carbs being different sizes? By this I mean the "L" shaped bottom bowl...I recently purchased a rebuilt carb(and it runs great) built for an "F-30"...the guy said it was the same as mine. Today I started to finish up the components and when I put on the air cleaner assembly- the tube attached to the carb sticks thru the hole on the engine plate about an inch...it should be flush- will not work. Just curious here whats going on....thanks.
Some power unit manifolds/zenith carbs were installed on 22-36's and could be
a little longer than for the w-30, not sure. Otherwise the rubber boot at the connection
I believe came in two different widths.
Thats possible; but I have the same boot that came off so it should be right...must be two lengths on the bottom part? I better try to get ahold of the carb guy! Thanks. Do you still have that pulley for me? I would come get it. Thanks.
