Farmall M Valve Tappet
I got a new camshaft for my Farmall m and heard it?s a good
idea to get new valve tappets on a new camshaft I found
these from Steiner tractor but they don?t have the holes on
them like the old ones do it says they fit, would these work?
Thanks
you can get the old ones resurfaced easy if they need it. Check the surface of the old ones to see if they are still flat no need for new ones. A VALVE GRINDER can resurface the old ones if needed
I agree with Gene, the springs and rocker ratio ore minimal on these engines. A cleanup of the existing tappets is all that is needed. Jim
