Removing sleeves
When removing sleeves a guy take a welder and put a light bead of weld inside of the sleeve to shrink it. I have done this on bearing races and it works good
you bet, its the easiest way. i weld a vertical bead 180 degrees from each other and stick my hand in there and make a fist and they pull out. just be careful not to get to hot and burn throught the sleeve. then you got a problem.
