ShermanPowerDigger
Ok, I am lost on this one. I ain't got gasoline running through my veins so please bear with me. My 404 just doesn't want to start. I took off the carb and had a tractor dealer's shop rebuild it. Also I replaced spark plugs, wires, points & condenser, dust shield, rotor, cap.
It almost wants to run but not quite. When I hold my hand over the air intake and suction builds it will try to run until I let air by. If I pour gas down the air intake it will run sweet and move through power ranges, when my cup of gas runs out it will run on for two or three minutes.
I am adjusting the idle screw, while it runs on dribble gas, per the operator manual instructions in the hope I get lucky. My next planned work is to pull and clean the entire air intake assembly and add fresh oil in the cup to insure that is not the problem.
And I will drain a pint of fuel from the carb and time how long this takes as I have read about that here. Since I can pour in gas and it will run as it should could something be wrong with the rebuilt carb? As noted above I'm not a mechanic but should I pull th carb again and if so is there some literature available to review the steps to rebuild one? Easy literature with pics that someone with limited ability can follow?
How a carburetor works is a mystery to me but if I have to slug my way through it I would like to know. I also have a zenith carb in an old truck that needs rebuilding and maybe I could at least try to figure out the mystery of the carburetor with some help.
I don't have much hair left and the way I'm pulling it out now on this 404 I'll soon have none. This tractor ran very good last year but I just can't figure out why not now. Any help is appreciated, and apologies in advance for the stupid questions.
