Hotflashjr
- Location
- Western MA
Just got a cub a few weeks ago and it seems like the crankcase is making oil. On one of my JD's I had the engine mounted oil pump for the hydraulics had seals that could fail allowing oil from the hydraulic system to run into the crankcase oil. Is this possible on the cub? All of a sudden I have front and rear main seal leaking on the tractor and the oil level is above the full mark, which it was not when I bought the tractor 3 weeks ago. Antifreeze is same level. I did not check the hydraulic system oil levels when I bought it or now - just noticed last night after about 15 minutes of light use that I had some leaks that were not there before after a few hours of use.
