On a Case IH 7120 front wheel assist will
the oil pan drop straight down from the
engine after removing the drive shaft? A
friend of mine owns the tractor and the pan
has a crack in it and needs to be repaired.
I haven't looked at it yet but he thinks
it's not going to drop down between the
frame rails. Do you normally have to remove
a frame rail to drop the oil pan? I'm not
real familiar with them. Also does the oil
pan removal affect the rear main seal?
Thanks for any help.
