super h sediment bulb
when I turn the shutoff for the gas on the sediment bulb on my super h it leaks. it looks like the needle screws out is there something in there I can replace, I tightened it up and it quit for a while, any help or tips would be appreciated
If it is the original sediment bowl, or at least an original replacement, you can replace the packing. If it is an aftermarket replacement there is NO packing in there. Some kind of rubber O rings instead, and there is no fix. I am considering replacing the aftermarket units on 2 of my Farmalls with an in-line shut-off, an in-line filter, and eliminate the sediment bowl assemnly.
