super A hydraulic pump repair
tn terry t
my super a has started leaking fluid back in the crank case so I tore it down its the one with the o ring as a seal the dang shaft looks pretty ruff does anyone make replacement shafts and gears for these pumps
I don't know but I read there wasn't enough room for the sleeve between the shaft and the housing that's why im asking
Before you spend a lot of time and possibly money messing with a worn out pump check around, you should be able to find a good used replacement, there were lots of those sized tractors built and who knows how many have been parted out.
I know there are new aftermarket ones available, but they are pricey.
