B Steering coupler
Not certain what you mean by steering couper? If you are talking about the U Joint that conects the steering shaft from e steering wheel to the out end of the worm gear shaft on of the bolster housing THEN here is a method I use "" in the 1980 s my U Joint went "belly up" at that time I went to a serplus outlet, found a new one with the same sized hole as the saft dia. It was slitly more beefy but works excellenty. Did a mild modifecation to the shaft key. Now that the tractor is back runing again after being re assembled 20 some years late, all I did was to pump fresh greace in and voala good as new.
