Need to add some weight to the front of the BA
old
So I had to do my neighbors hay and used the BA to cut the hay. I have a long steep hill on my driveway and found that the front of the BA with the A16 sickle bar mower got a tad bit light on the front and was hard to keep going in a straight line. So I need to add a bit of weight to the front. I also need to replace one front tire since it is so thin the tube is almost as thick. At least I now have the time to sit back and weight out my option as for tire and weight since I am now done as for 1st cutting of the hay and not sure I'll get a 2nd cutting
Yes I know that but I also know finding them is like looking for hens teeth, almost impossible to find and if you do you pay big time for them
If you are not worried about it looking pretty make up a box to go off of the front of the frame and put rocks or other ballast in it.
There are two holes on each side of the front bolster near the bottom. I would find something from the scrap pile (like an old grader blade) and cut it up into 14 inch pieces. I would then make a bracket for these pieces that would cup the bottom of the blade pieces when they were stacked, and hav a lip on the outside edge to keep them from scooting outward at the bottom (Like a capital L with a tab sticking up on the right end). I would bolt it in place, stack on the pieces, and bind it into a lump with ratchet straps. I would (on your BA) put it only on the driver's side. The design would allow you to put it together without lifting the whole thing as a weight. Jim
I don't do flea bay for 2 reasons. Dial up and flea bay do not work well and I don't test much I can get on line like those.
I have a few old weights that are for maybe a pie type wheel weight I am thinking about putting on close to the front. Never have been able to figure out what the weights came off of but I have them just laying around. The bigger ones are about 34lbs and the smaller around 25 so in my range of lifting . LOL Lifting and what the doctor says I should do does not get along with life. LOL. Doctors says 35lbs max but life does not let you do that all the time but I do try. I'll have to look it over and see if I can bolt them on with very little trouble. As for what side I run a set of duals on the narrow side so as to help keep it from flipping on the nondrivers side
Don?t laugh.
When I was younger we had a mower for our 8N that was a little too heavy. If I was mowing on a hill I draped a sandbag from the old pickup over the hood. We used old truck inner tubes and cut them, filled them with sand, and then twisted the ends shut with baling wire. I must have looked goofy but it worked for something I didn?t need that often.
I looked at it this afternoon and there are 4 bolt holes on each side of the front. 3 are treaded and one is not on each side. Now if I can figure out where I hid those stupid pie weights I'd be in business
I found 2 sets of IH front wheel weights on Craigslist in your area. $125 & $200 is what sellers are asking. Doesn't mean that's what they will get. I paid $150 & $200 for the 2 sets I have. Time I was done, cost way more than that. 1 set came from Michigan & other set from New York. Then I had to pay shipping from Ontario to Alberta. I would be all over those weights in your area. I wish old tractors/parts are like you guys have, out west here there is nothing. What is really over priced is wheel weights for the 18" front rim, bend over & your not going to get kissed either.
The BA I built has 15 inch front rims with either 400 or 500X15 tires. I need to replace one front tire yesterday but that is another story. As for paying that for weights I'll not do that since before I would do that I could go to my scrap iron pile and make what I need. It just gets me that the front of this is so light that going up a hill the front tried to go every where but where I was trying to steer it.. Shoot I may even fil the front tires with wiper fluid.
Now the part thing your talking about that is why I will not scrap a tractor. I'll let it lay in the fence row before I sell it as scrap iron since sooner or latter some one will need a part I have
I have a couple of grade 8 bolts that are about 6-8 inch long I figure I can use now I just have to remember where the pie weights are hiding
