I keep pushing seals out of hydraulic pump. The main use I put on it is running Char Lynn ps. It is plumbed with a priority valve in pressure line from pump. Priority line goes to power steering and return from PS to liftall box. Other line from prioity valve goes to a double spool valve. Relief at spool valve is set at 1000 pounds. Return from valves goes to lift all box and return from there to pump. Do I need a relief valve between priority valve and PS unit? Is there some type sealant I can put on pump seals so they don't push out? Anything else in pump that would cause excess pressure to push seals out. Would running too much oil to ps unit cause this? I would appreciate any help on this pulling my hair out.
