Gordy1
New User
Hi I'm having a problem finding the engine model number on my 784 I believe it begins with a letter followed by three numbers its an 84 series does anyone know where to locate it I need it to find replacement parts for the engine rebuild I believe.
Thanks
thanks IH Timmy will have Look[/quote]
From my owners manual:
Tractor Serial Number - on rt side front of engine, under the fuel filters on a tag on lower portion of front bolster.
Engine Serial Number - on rt side of engine just aft of the oil filter and above the engine oil dipstick.
Skidded Unit Serial Number - on left side of engine on bell housing and just to the rear of the starter solenoid.
Hope this helps
Hi I have had a look but cannot see any I.D number on the casings would you or someone post a photo of this number & the area so I may get a better idea where it should be if possible the only number I have found is on the block which is '96' which doesn't mean anything to me.
Hi Gord,
Attaching a couple of photos from caseih.com parts site for 784 Serial Numbers and Suffix letter codes.
Hope this helps
JimB
IH 784 Serial Numbers Locations
