706 battery tray
urbancase
guys do any of you have a left side battery tray that you would want to sell ? they took the duel 6 volts off and put one 12 volt on and cut up and welded the left tray up. when I restore it this winter I want to put it back to duel 6 volt batteries again.
e-mail is open.
thanks
Why? Those batteries are the worst for lasting. I had those in my 806D was always changing them about every 3 years. Now use the 31's with the stud on top last twice that and half the connections to deal with.
I do realize the original factor, though not enough to go back to those.
there may be places that make reproduction trays like tisco or A&I. as for batteries i have been having bad luck with the case ih batteries . bought a 6 volt for the M only lasted 2 years. bought 2 6 volts for the 706 only lasted 2 years bought 2 12 volts for the 3394 onlt got 3 years out of them. I have had good luck with deka batteries got 13 years with them in the 3394 and 10 years in the bobcat. my dads JD 130 lawn mower battery lasted 6 years and his 856 had 2 6 volt JD batteries that went 8 years so i put Jd batteries back in it but i turned the JD logo in so no one could see it
