jesseholmz
I have a few issues with my IH 574 regular gas:
1. At some points hydraulic fluid will spew from the steering column. It results in always having to refill the hydraulic fluid. I'm guessing it's a seal of some kind but how much of an in depth fix should I expect? It's my only tractor so I'd need to plan to not have one ahead of time
2. I've had overheating issues while baling. The radiator does circulate but eventually starts to overflow. I tried hosing down the radiator and then blowing it out which seemed to help a bit. Do I just need to keep cleaning it out? I was told I could try spraying it down with some soapy water and then hosing it out.
