behlen gear box
marlin54
On this Behlen ...which port is the inlet from pump...and which is the return to tank or outlet..
Trying to find out which port on this behlen Torque motor is the one to use for pressure coming in to gear box and which is return to tank.
Feed line from reservoir goes to bigger pump opening, small opening on pump goes to small opening on steering unit. Larger opening on steering unit goes back to reservoir. 1/2 inch suction line from reservoir to pump is good enough for that pump, but it may be better if the reservoir was mounted higher.
Thank you for the reply. Going to try and leave tank where it is. But I know to get it primed is going to be a little harder . Also added a prince valve and I will plumb it keeping in mind what you have told me.
