27A sickle bar mower
Dave41A
Good morning. What size (hp) and weight tractor would be needed to pull an IH 27A sickle bar mower. Could an "A" do this (wheel weights, no ballast), or do I need something heavier or more powerful? Will be used on mostly flat land with a few gentle hills for mowing hay--maybe 20-25 acres. Any other thoughts would be appreciated. Thanks in advance. Dave
Thanks, Gene. I take it the "A" is big enough then, weights or no weights?
Also, I should have called this a "27VA" mower, not "27A." Sorry for any confusion.
