Super m front wheel centers
4010tim
I am looking for a set of front wheel centers to go on a Farmall wide front end for my father in law's super m. The centers off of the narrow front will not work on the wide. I can find aftermarket six lug hubs, but I am having a problem finding original type to put on it. The wide front he has is in good shape, but has no front hubs on it at all. I am in central Michigan so any advice on places to look or to contact would be appreciated.
Try Harvey Gross if he is still in business. Was real reasonable and had lots of Parts for the IH and Deere. If it is an after market axle I am not sure if you can get the original hubs to fit at all. Schwartz or any of those types.
There is a place at Farwell I have not been there yet as it was it is over an hour away. Not sure how much he has either.
Without knowing the type wide front makes it hard to give a defiant answer. If the old IH type with tie rods forward of axle they used H or SH size wheels. If a latter type IH and the SM ones won't fit the spindles could be from a 60 series or newer. If a aftermarket wide front need to do some spindle measurements.
Barnyard not always, check the spindle numbers and wheel castings used on the IH adjustable wheelbase wide front with tie rods forward of axle on a H, M, SH, SM tractors. Later wide front with tie rods rear that came out in early 54 used the same narrow and wide front wheels until the 60 series.
I haven't went to look at the front axle yet. He said it takes the
same front hubs as a H or maybe a C. The axle is still up on the rack
so I need to get it down to ground level so I can see the whole thing.
I don't know is how he even ended up with a front axle with no hubs to
begin with, all, I can figure is it must have been free/extremely
cheap.
Is Harvey Gross on M-13 by Elmer Gross? That wouldn't be too bad of a ride for me, I just never go that way.
Where is the place in Farwell? I will be headed that way in a couple weeks and to my wife's dismay could schedule a little detour to see what they have.
Try a set from a Farmall H....the old style wide front ends (the one with the tie rods up front) used the smaller spindles from an H. Give it a shot, you may luck out.
