The governor operates properly as far as idling and throttling up but for the first 3” or so of the throttle handle it doesn’t do anything until after and then it will start throttling up. I took the cover off the side and the spring is not stretched and I see the 2 adjustment screws and the screw on the throttle linkage. The arm that the spring connects to doesn’t start actually pulling on the other arm until you get past that 3” of play. The high idle stop screw goes almost against its stop and the tractor does idle all he way down. What do I need to adjust to take up the slack so there is tention on the spring?
