Hotflashjr
- Location
- Western MA
I posted about buying a cub last week - went and got it Friday. The tractor sat for a year inside before I bought it. I drained out the old fuel and put in fresh gas. The issue I am finding is I cannot get the tractor to run the mowing deck without stalling or without having to slip the clutch to keep the RPM's up when starting out. I adjusted the carb and governor linkages and that helped some. It does get up to full operating RPM within a minute or so of moving if you slip the clutch to get going. Is this normal? I ended up mowing my yard with it and although it is not green I still enjoyed the ride.
