Question on top final drive seal replacement on B
jkmdg84
I need to replace the right side top final drive seal. What I am wondering is am I able to just remove the differential shaft in order to replace the seal and leave the seat, platform, and housing still attached to the tractor? Didn?t know how difficult it would be to reassemble and line up the shaft back into the differential with all of that still attached. Thank you!
yes remove the final and the shaft will come with it then you can remove the shaft and replace the seal. You need to remove the wheel and center first unbolt the drawbar
