560 hydraulic filter
Hayfarmer
I pulled plate off over filter and the screen was plugged. Cleaned it up and hydraulics and PS working again. Is it only supposed to pull oil through screen when other filer is pulgged?
I was thinking that was what I was told by an old timer at the IH dealership. guess I better go ahead and change filter again. I changed it not very long ago, less than a month, but I don't remember cleaning that screen then and PS hasn't been working even after I changed filter before. thanks for the help
(quoted from post at 21:27:17 06/23/18) I pulled plate off over filter and the screen was plugged. Cleaned it up and hydraulics and PS working again. Is it only supposed to pull oil through screen when other filer is pulgged?
It depends upon which filter you have. If you have the original style filter with the two "donuts" all the oil goes through the screen to get to the small filters inside. Later style filters use the bypass screen that will open in cold weather of when the filter is plugged.
