My 450 has developed a leak at the hydraulic pump. It looks like the oil is coming out around the split to the front of the pump
as it sits on the tractor, and is also coming out around the bolt heads. Would the gasket that seals the pump halves be leaking,
or is something else going on. Is this something that is repairable, or do I replace the pump? Finally, is there someone that
rebuilds these pumps? Thanks, Jeff
