Spring and small wear tube super c pto
grampsh1
I removed pto housing on super c to remove rear axles for oil seal replacement and layed on side on shop floor and a spring and wear sleeve fell out of place I believe it is to hold pto lever from engaging when not required I’m thinking the wear sleeve goes against the lever then the spring can some one post a picture or tell me where I might find a diagram so can reassemble properly Thanks for the help
Paul
(quoted from post at 17:42:19 06/21/18) Not sure how much this will help. Worth a shot. If you are very computer savvy you should be able
to see any part of your tractor. See link.
Case IH on line parts
hanks for help I think I have figured out now the parts diagram was quite helpful thanks again
