farmall 300 radiator
dewy
patchin up a radiator thats really rough...had a hole where bolt broke off up in radiator the size of your little finger...patched it up with stuff out of scap pile...question is what do you use to get the frame welded or soldierd to radiator...metal of frame or bracket will not take 50/50 soldier...what will stick to metal an brass bottom of radiator...........thanks as always Dewy..........
Think I just used acid solder but you have to get it super clean. I use small tooth brush size wire brush, heat and brush, melt a little solder on it and brush until clean. Then hold that tab down and do your thing.
