IH hydraulic buzzing noise
Bkpigs
My Farmall 504 has a high pitch humming noise from the hydraulic lines. The lines also have a vibration to them. What would cause this? It is not a squeal like a dead headed line, just a high pitch humming. Also, the power steering is on the weak side. The fluid is fresh. Is there a check valve or relief valve that could be causing this?
