TWL
I have gone through the mcv valve. New pump,o-rings etc. I have the Blue ribbon service manual and IT manual. Measured the replacement gasket for correct thickness ready to reinstall. I made studs to help slide mcv into location. My problem is I cannot see what o-ring or o-rings are necessary between mcv and transmission housing. I have looked at the service manual several times but just can't get it. when I removed it there was one near lower left about 1" and 2 near the top at near 1/4. Could anyone give me some advice on how many there are? I do have the small spring for the steering check valve in the right location. Any help would be greatly appreciated.
1086 I was old they all were the same with the ta. Still needing the answer, anybody know?
Should be just one near the bottom. Be sure to use the correct one. Too soft of material in the O-ring will result in it blowing out since it is subject to steering pressure.
