560 PS flow control valve
Hayfarmer
Power steering off and on then quit completely. I hydraulic filter and oil but didn't help. Main pump is fine with good pressure. If I put a pressure guage n port behind where ps line takes off it shows about 300 pounds pressure when I turn wheel. I was looking at service books and was wondering if the flow control valve could be the problem. I realize I have to pull the pump to get a look at it, but what should I be looking for in the valve?
