Fasthitch to 3 point arms
DANWV
Looking for the arms to put in my 544 fasthitch arms so I can use 3 point equipment. Could have some made if I knew dimensions. Does anyone have pictures of the arms and the top link installed they could share?
Thanks.
IHC did make a 2pt to 3 point adapter, or what i thought about doing is buying a 3 pt quick coupler and grafter some 2 point horn's to it. The 2 point is about 28 inches wide and will fit inside the 3 point coupler.The top link you have to be creative and wrap a 3 inch flat piece of 3/16 or 1/4, around the shaft for the 3rd link support!
There is no "one size fits all" for the adapters. Fast hitch is 28" wide while Cat II 3pt is 32" and Cat I is 26". So it will depend on the implement you're trying to hook up which adapter you get.
Really if you can imagine in their simplest form, they're just a fast hitch spike with a 3pt hitch ball welded to the end. Google "fast hitch 3pd adapter." Agrisupply has the fast hitch spikes for $50 each, and you can get weld-on 3pt balls at any machinery dealer or farm supply.
i bought some adapters from tonys tractors, he has a website, for my 240utility. it has the large point fast hitch. the points are long for the 240u,
so i cut about 4 inches or so off and welded them back together. i like the quick attach instead of the spee balls as it is easier to hook up
implements. heres a pic
Find the factory 2 to 3 point convertors big prong for what you need and you can switch the lower lift links from side to side to get category 1 or 2. I have five or six of them, mount them on three point implements and them on there.
I made up a set for our 340U, had a little offset to make them fit cat 1. I made a top link bracket, all worked great! Back up to within 4 inches of implement, slide the arms out and hook them up, then back up until they latch, easier than a regular 3-point.
