Trent Couch
I have a wide front currently on my M and while doing some maintenance on the front end wheel bearings etc I decided to replace the bushings in my center tube they were worn very badly and after replacing the bushings I replaced the center tube pivot pin to tightened everything back up. While I was doing this I took off my saddle and got a new stay ball socket and cap now the problem I am having is that I can?t get the saddle back on no matter if I pull the pin out some and try to wiggle the saddle on it will not squeeze in the frame rails it?s to tight, the pivot ball on the wish bone appears to now be to far up. I even tried putting the old stay ball socket on with no luck. I know I can mill some off of either the saddle or stay ball socket to make it fit but this has got me scratching my head as to why it won?t fit back on? Has anyone else experienced this or have any suggestions? Thanks
