behlen steering problem on md
ikeinNC
New User
I have an MD with a Behlen steering on it. I've had it for years, it's building pressure in the reservoir tank. Does anyone know of a cure, or what's causing it. Thanks
If the pump being used is sucking air on the intake side it will discharge oil from the cap. What pump is on the tractor? Jim
Thanks Jim, it has a Behlen pump. I normally keep the tank about half full. The system came off an MD that was hardly used. It has worked really well until now and has blown the front seal out.
