Ken Christopherson
Hello all!
Well, I looked at a Stage 2 Super M today. Runs good, idle is a little rough (easy fix). Question is, it grinds pretty bad going into 1-4
gears even at an idle. (Doesn't matter how long I wait for the input shaft to stop turning)... Belt pulley grinds when engaged as well. To
me that sounds like the clutch isn't stopping the shaft from spinning. Typically does this warrant the clutch needing to be adjusted or
more of a replacement? Otherwise tractor seems pretty nice. 12 Volt with generator. Lights work. Tires checked but hold air. Rims good. Tin
straight, some dents in grill.
I would be selling my 1947 M to upgrade to this tractor... It is either that or I would create a project for myself by keeping the M and
installing all Super M hydraulics/cam gear onto it for loader work.
I'm looking to make the purchase soon, so would like some input please and thank you! (Picture is of the tractor)
