I posted about installing new seals in this factory live pump last month. Did that and everything went smooth and worked as before w/no leaks & no noises(as before). I let it stand for 2 days and started it and got a whinning-buzzing comeing from hyd. pump now. The faster the engine rpm the faster the noise and I can feel this vibration in the hoses from the pump to the under tank control. Could this be air in the system and how do I bleed it if that is what it is??
What is the function of the ball & spring under plug on top of hyd. pump?
Thanks, Appreciate all the knowledge from ALL.
