TractorLinks.com
Show Parts for Model:
Timing tape
FastFarmall
06-13-2018 20:42:13
So is there a source to get some timing tape, to stick on the crankshaft pulley, to figure out about where 22 degrees is, or just go about half way between the two marks that are on their with a white marker ?
john *.?-!.* cub owner
06-14-2018 19:45:39
 Re: Timing tape in reply to FastFarmall, 06-13-2018 20:42:13
Adjustable timing lights are available that you turn knob (old ones) or use a push button to select advance, and only need the TDC mark
gab
06-14-2018 12:21:28
Think it might of been Pete 23 that said 22 degrees at full throttle was 1 + 7/16 before TDC.
David G
06-14-2018 07:28:52
You can easily time it by ear and get real close.
open throttle clear up, rotate distributor so that engine is at max RPM, idle down, if it lopes, retard a little bit.
d beatty
06-13-2018 22:02:50
IH use to give you a template with over haul kit to mark pulley and take a three corner file and cut a new notch at 22 degrees.
FastFarmall
06-14-2018 16:59:26
 Re: Timing tape in reply to d beatty, 06-13-2018 22:02:50
I know, but this M has TRW pistons,but it all been good info, thanks guys !
DeltaRed
06-13-2018 21:36:08
I use white 'Correctotype' correction fluid. Comes in a small nail polish like bottle with a small brush
Janicholson
06-13-2018 20:54:03
Mark 180 (half way around) on the pulley starting at TDC . Divide that in half (90 degrees) divide that in half 45 degrees. Divide that in half 22.5 degrees. Or measure around the pulley with a cloth tape. Divide that number by .125. (22.5 degrees) Jim
FastFarmall
06-13-2018 20:56:15
 Re: Timing tape in reply to Janicholson, 06-13-2018 20:54:03
Thanks Jim, you're a genius !!!
Janicholson
06-13-2018 21:01:47
 Re: Timing tape in reply to FastFarmall, 06-13-2018 20:56:15
I work toward that goal every day. Thanks. Jim
