Hey guys, I hope this is the right place for this. I ran across an
international 300 utility tractor. The owner wants to give it to
me but before I took on a new project I had a couple of
questions. It has the 3 point lift on it but the lift arm ends, that
hold the ball to hook to an implement, are missing. Are these
parts still available? Also, I?m sure it will need a gas tank. Are
those available or would I have to clean and work with the
factory one?
I?ve always had fords so anything you can tell me about these
tractors would be well appreciated. It?s very straight, has all
the gauges in place, doesn?t look patched up, and was
running when parked. Tires are even holding air.
Thanks!
factory one?
Thanks!
