TractorLinks.com
Show Parts for Model:
Re: Farmall H Governor adjustment problems
gmcdeadhead
06-13-2018 03:05:00
would anybody no the fix for this?
Bob in wc Ia.
06-13-2018 06:01:38
 Re: Farmall H Governor adjustment problems in reply to gmcdeadhead, 06-13-2018 03:05:00
gmc, You might try loosening the 2 screws where the throttle shaft tube connects to the carb and remove the 2 flange screws on the vertical housing. Slide the flanges away from the housing and tighten the screws at the carb. The tube should not be tight against the opening in the housing. If there is a problem , you'll need to clearance the hole so there is no binding. Do you have an aftermarket manifold? Have you replaced your horizontal throttle shaft? Just a couple things that may contribute to the problem. Bob
