TractorLinks.com
Show Parts for Model:
Re: Farmall H Governor adjustment problems
gmcdeadhead
06-12-2018 08:39:03
dieseltrks3, did you ever fix your governor problem?
gmcdeadhead
06-15-2018 09:13:40
 Re: Farmall H Governor adjustment problems in reply to caterpillar guy, 06-12-2018 08:39:03
---UPDATE---, i toke the throttle shaft connecting rod out of the governor, i used a 1/4-28 die and added about 1" of threads to the rod, now the pin moves freely at wide open throttle, added a new governor spring , put it all back together , took about and hour, runs great , maintains speed when under a load , hope this fix helps someone else.
gmcdeadhead
06-13-2018 09:22:53
 Re: Farmall H Governor adjustment problems in reply to BrianV_, 06-12-2018 08:39:03
ok, might be about a week till i can get to it , but i'll let you no how i make out, thanks
gmcdeadhead
06-13-2018 08:42:02
 Re: Farmall H Governor adjustment problems in reply to JDEM, 06-12-2018 08:39:03
bob , i was thinking of doing that, but would it effect anything by just adding a few more threads to the rod?
Bob in wc Ia.
06-13-2018 09:08:26
 Re: Farmall H Governor adjustment problems in reply to gmcdeadhead, 06-13-2018 08:42:02
No, shouldn't hurt anything. Bob
gmcdeadhead
06-13-2018 06:11:00
 Re: Farmall H Governor adjustment problems in reply to jimb2, 06-12-2018 08:39:03
i never replaced the horizontal shaft, it still looks good , no after market manifold, i loosened all the screws you talked about , everything is fine and rotating freely. carb is rebulit , tangs all line up, the tractor im working on is a w4, maybe all the internal parts of the governor are worn out , they appear to still be good.
Bob in wc Ia.
06-13-2018 07:51:49
 Re: Farmall H Governor adjustment problems in reply to gmcdeadhead, 06-13-2018 06:11:00
Looks like you'll have to thread the rod about 4 more turns. Take the 2 bolts out at the base of linkage housing. Turn and lift off. Remove throttle shaft assembly if it/s in the way. Good idea to put a rag over the gov. to keep metal out of the engine. Remove jam nut and clevis. Thread with a 1/4-28 die. Reassemble and adjust. Sounds complicated, but really not that bad. Hope this helps. Bob
