Jwr0907
New User
Hey anybody know the torque specs on connecting rods and mains on a td7e /d239 engine sure would appreciate it
Great thanks is 64040 sleeve retainer high temp best locktight to use on sleeves and it needed to be applied under top of sleeve and around bottom of sleeve?
They are wet sleeves. I have never had to use any kind of sleeve retainer on a wet sleeved engine. The o-rings seal it on the bottom and there is a small amount of sleeve protrusion on the top where the head gasket seals the top of the sleeve to the block.
The sleeve is flanged on the top as well, and it sits in a counterbore in the block, it is mechanically retained in place.
Maybe I am wrong, but I just don't think that is needed for this engine.
If ya knew what you were doing and how to check on what sleeve to install you would NOT NEED any GLUE to hold the dry sleeve in .
I am pretty sure that I wasn't talking to you Tractor Vet, and awesome way to try and insult someone.
I have installed tons of dry sleeves in tractors and never needed "glue" for them either.
Some automotive type "dry sleeves" are either pinned or glued in place because they do not have the counterbore at the top like engines that originally came with sleeves.
