Pearl_Sutton
IH 2444 #05123 about 1969 version, I think. It has a loader and 3 point, has connections for back hydraulic but nothing hooked up to it.
I have a manual ordered but do not have it yet. Need the tractor running, I have work to get done ....
What is the correct amount of hydraulic fluid for this thing? The shop manual I have says 3 gallons, but I have drained off somewhere around 8! I was told that how it was running it sounded like it had too much fluid, try taking some off. I did, then more, then more, still couldn't decide if it was correct. I decided I'd drain it totally and start with a measured amount, since I'm not doing well at guessing what the level should be. But 3 gallons is looking way too low, and I think that may be for a machine without a loader installed.
Secondary question to this: I'm draining it off at a female square holed magnetic plug that faces the back of the tractor. It's above the 3 point, below the male plug that sits on the top of a cubical reservoir thing that is below/behind the seat. There is a male square plug on the underside of what I would say is the axle (?) or transmission (?) just below the reservoir, drain plug for the axle or whatever. Am I draining it at the correct place? Do I have all the fluid out? Not sure if I should be trying to get that square plug loose, it will take serious work, it's not easy to remove.
I apologize for not knowing the right words for what I am seeing, I'm good with cars, but trying to learn a tractor from scratch. I'll do better with words when I have a manual.
If it matters, the reason I was told the take off some fluid is it ran fairly well, I did a bunch of brushcutting before the grass got thick, then blew a hydraulic line. I replaced it, wasn't sure of what the fluid level should be, added some, and the tractor is now losing power when I am running the brushcutter, to the point where it loses power going uphill with the cutter off, running on grass I have already cut. I have been concerned I am going to get it stuck because it can't go up the hill it has gone up easily before. I was told too much fluid could be making the clutch slip, take some off. (If there's a way to clean the clutch easily without taking things apart I'd love to know it!)
Any help anyone can offer would be GREATLY appreciated
Pearl
Pearl
