Afternoon,
I had to replace the points in the distributor on my '52 Super M. When they failed I was away from the house on a Sunday so I ended up pulling the distributor and throwing on a mag I had to get home.
Anyway, new points in, mag off, distributor installed. I installed it by the book, it started right up and idled away.
For the fun of it I threw my timing light on and found at low idle I was pretty much on TDC but at high idle I was only getting 12 degrees of advance. My book says the SM should be about 30. 12 seems pretty low to me.
This machine has stepped pistons in it, I don't know if they're the run of the mill type you can get today or if they're legit IH Firecraters. I know I've read with the Firecrater kits the timing was retarded so I guess that's a possibility. I do know with the mag on it idled pretty poorly but those things are 40 degrees as soon as the engine spins up.
Other than tearing it apart to see if the weights are sticking is there a reason why I would be missing so much timing?
K
K
