I just bought a 484. It has 5000 hours and seems to be in good condition. It has two hydraulic lines and the back and I know the lever on the right activates then. Is one pressure and one return? Then you can reverse the fluid depending on if you move the lever up or down?
Does the PTO have a built in one way clutch? Or should I put one on?
I can't find a serial number decoder online. Its B480907B009540-X
Its supposed to be a special version for going down rows.
Thanks for the help.
Jon
Jon
