68 cultivator will if fit on wide front 856
You may have to reconfigure the shanks udder the belly.
I believe we had to weld a piece with a hole on the cultivator to bolt to the frame rail also.
Frame rail is to wide for the factory brackets that attach it to the frame rail after you swing it in ( I think).
The front side rail bracket will work. AS will the bracket above it for the angle brace.
We may have modified the gauge wheel arms a bit also to allow the tires to turn side to side. The size or your front tires will make a difference.
This was 48 years ago so I am a little foggy on what all we had to do but we had a 68 on a wide front 856.
