Who makes 3pt hitches for 48 H
Worksaver makes one. On their website it is listed under "International Harvester Tractors" instead of under the "Farmall Tractor" menu.
Just make your own. If you can weld/fabricate,no problem. Or get a buddy who can weld and 'draft' him for a weekend.Use top links for the 'leveling cranks',a chunk of 2" solid shaft for the rock shaft,pipe for the pivot 'bearings'. I made several 3 pts,from H to 560.For a couple hundred bucks(less if you use 'used' steel,useing your own cylinder) and sonme time/labor. Done deal.
I bought an economical 3-point many years ago and after plowing, I twisted / bent the 2" circular shaft. Had to have it taken apart and redone. I'd recommend a hardened steel alloy steel shaft of some sort.
DR, I can weld good enough. BUT, I have no idea what a rock shaft is, OR where it goes,
Are what you call the pivot bearings, the inner and outer ends of the arms?
I Only want to use it on a post hole digger.
Where does the cylinder mount at? I have a 2 way cylinder. I think it can be used one way. I thought about making it. Got on U tubes, but didn"t see anything.
The 'rockshaft' is the big round shaft that pivots.It doesthe acctual work of lifting.Look up somr three points on the internet. You will get an idea of how they are made.
By the time you accumulate all the steel and hydraulic cylinders to "do it yourself", $1,000 will look pretty cheap.
Saginaw County Tractor ( www.saginawcountytractor.com ) used to make nice 3 point hitches for older tractors. Maybe look for a used one?
Try these people. I think they actually make the hitch.
Cross Machinery & Manufacturing
301 Main St
Mindenmines, MO 64769
(417) 842-3405
