Aux. valves
My 504 has 2 aux. valves. Only one was ever used. The one on the right (non detent) is what I want to put hoses on. Anyone know where to hookup to? Do the hoses go to the valve or to another point. My manual doesn't tell me what I need to know.
I guess I wasn't clear on that, let me try again. The (non detent valve) was never hooked up, so I'm trying to figure out where to install the hoses. The detent aux valve is the only one in use.
They would come off the valve in the same place as the ones for the first valve. These are the valves mounted to the right of the seat, correct? The tubes come off the bottom of the valve, and if there are no tubes, hopefully someone was thoughtful enough to plug the holes.
The valves can take standard O-ring style fittings. Can't remember if they're 1/2 or 3/4, but if you take the plug with you, you can match them up.
This is what I'm talking about. In this picture, there is only one remote valve, but you can see how the lines come off the bottom:
Thanks a lot, mine is somewhat different but there has to be a place to hook up to. I'm going to look again. And yes, it is a utility 504.
It probably never had the lines installed under that valve. There is two hexagon plug?s you remove and add the lines with longer banjo bolts You may be able to put fittings in the holes but do not remember.
