where do these pieces go.......
I've done that ... rebuilt a 4-barrel carb for my old El Camino 350 on the kitchen table, and had lots of springs and balls and screws left over. I put them in the kitchen drawer, and the chev ran just fine.... sorta.
If you get the full carb kit , the one that cost around 75$, you will use all the piece and have none left . If you did it right and now how to rebuild carbs,
Do these two go together?
go to the case ih on line parts pages . the little washer goes in the botttom of the carb drain hole . thats where the gas comes out when it floods. the little ball goes behind the choke lever
Well .the disc with the hole goes in the bottom in the drip hole with a felt packing and the ball is for the choke detent alng with a spring that went flyen when the choke shaft was removed
